2012-05-0812:28 AM - last edited on 2023-05-2304:35 PM by Rubia Torres
Window Boundary Cutting into 3D objects
2012-05-0812:28 AM
How can I stop these windows doing what they're doing in the picture?
They are cutting a chunk out of the top of that wall that you can see to the right of each window.
If it makes an difference, the window and the bit of wall that is being cut out is part of the same complex wall profile, but they shouldn't be doing that because the opening lines in the complex profile are set properly to just the left hand side.
