Level Dimension
Hi.
I have a problem to use Level Dimension.
I want to show the story level by using Level Dimension.
I don't want to use Label or Object.
How can i do it? Is it impossible?
Place a Slab the top level of which is the same as the Level of the Story.
Activate Gravitate to Slab. Then place a Level Dimension with you cursor over the Slab. You can then even put that Slab o a hidden Layer if you otherwise don't need it.
Look at the picture.
I want to show +50(current story level)
not +6,050(project level)
I think the only way to do that is to select the Text portion of the Level Dimension and switch from Measured Value to Custom Text and type the value you want displayed.
