2003-12-22 11:45 PM - last edited on 2023-05-25 06:24 PM by Rubia Torres
2003-12-23 06:23 AM
2003-12-23 05:20 PM
David wrote:No...As it stands right now, when we create a new file from a template, we check the viewsets for the lists before saving...
Just a hunch - but once you start a new file from a template do you "Save" the .PLN file before checking the Viewsets?
2003-12-23 05:25 PM
2003-12-23 07:15 PM
David wrote:Yes, we check the template and save the file...If we close ArchiCAD and open the file, we almost always have to re-open the file before the lists appear in the viewset....It's as if the view sets load before the library is fully loaded...
Have you checked to see if the Viewsets are correct after you save the file? There are a lot of things relating to the ArchiCAD database that only work correctly after the file is saved to it's own unique file name.
