2006-06-13
07:31 PM
2023-05-25
05:59 PM
Rubia Torres
2006-06-13 09:22 PM
2006-06-13 09:25 PM
Steve wrote:The drawing to which you are referring must have first been placed on a layout, or you will get the "undefined" message.
Perhaps I am missing something (as usual.).
2006-06-13 09:26 PM
2006-06-13 09:36 PM
2006-06-13 09:53 PM
Steve wrote:It is true that you can only refer to other sections, but there is no reason that you can't use section windows exactly like detail windows. (Used to do that before AC9, anyway.) Just put a bunch of empty section markers on a separate story or a hidden layer.
Yes Richard,
The the Layout is the only place the refrence numbers are important unless you want to print directly from the model view.
It it true that you can only "Refer" to Sections?
Also, it looks like you can not "Refer" Details to anything. The dialog box will be empty when you try to do this.
2006-06-13 10:37 PM
2006-06-13 11:25 PM
2006-06-13 11:52 PM
2006-06-14 12:18 AM
2006-06-14 12:20 AM
Steve wrote:This sounds great, Steve. But I can't find any place in a section marker dialog box that will accept Autotext References. Where exactly are you placing this Autotext?
After you "Set as Autotext Reference" a Detail or Drawing in your Layout it creates a new Autotext that you can place in the reference number area of your section. Now the reference marker in your Section will match the Detail or Drawing the Autotext was created with.
