Zdenko
Log Wall
trying to figure out how to use the complex rectangular shaped object as a wall. after selecting the complex profile wall option, i don't get the profile desired. you can see in the foreground snap shot it is smooth vs. the standard log wall that shows the log  profile break lines.
Screenshot 2025-02-13 at 10.31.26 AM.pngScreenshot 2025-02-13 at 10.31.40 AM.png
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
6 Replies 6
Jeff Thompson
This is my best guess...  I really don't design using this feature.  My apologies if you've already considered this.
Project Manager
Rutledge Maul Architects, PS Inc., Seattle, WA
Windows 11 Pro, HP Pavilion Gaming Desktop 790, Intel(R) Core(TM) i7-8700 CPU @ 3.20GHz 3.19 GHz, 32.0 GB RAM, 64-bit operating system.
Archicad 28 - Graphisoft Forward
If you are trying to use a complex profile wall, then you have to stack as many logs as you need in the profile itself.
But the number of logs is not adjustable.
If you are using only one log as in your image and then stacking the walls above each other, I would place the origin ad the bottom of the log.
Whether it is in the centre or edge at the bottom is up to you.
The log wall option will only give you round (but segmented) logs.
I don't think you can control the size of that chamfer.
Zdenko
thanks jeff for helping, your screen shot is what i have been typically using state side. in this case we have a new log profile as shown in my post working with an outfit in Nederland.
Sequoia 15.1.1
Zdenko
hmmm ok barry appreciate the assistance but that is not what i want to do and spend unnecessary time stacking. will contact the company out of Nederland and see if they might offer some insight since they use an older version of AC and show that in their plan set.
Sequoia 15.1.1
Jeff Thompson
Roger that!  Good luck.
Project Manager
Rssr
Hi Zdenko,
I'm curious if you found out a new solution to your issue.
