Mats_Knutsson
Mentor
Looking for 3D-object tool
A generic beam/wall/morph-like tool that have different lines on the sides as shown in plan attach. It's for curbs'n'stuff. Anyone?
/M2021-09-28_12-57-20.jpg
AC 25 SWE Full
7 Replies 7
https://youtu.be/3WW5X7Q8FIc
I use this. I calculated material start points too so they follow the curve.
Mats_Knutsson
Mentor
How does it show in the plan view? I think I've tried this object sometime. Is it possible to download and test it?
AC 25 SWE Full
it will show each point of the profile poly line as a line in plan view.
It does not allow for different line types but this can be achieved easily with a simple algorithm.
https://bit.ly/BIMRithmPolyTube
Just figured out how to add custom profiles so I'll update you once I have it loaded into this object
Mats_Knutsson
Mentor
Hmmm...it doesn't show up with the object tool!? I've loaded the objects as embedded but can't find the anywhere. Are thy working with another tool?
AC 25 SWE Full
Load the whole folder not just the objects.
And I don't ever embed anything so I can't say it'll that's causing an issue.
I can make it an lcf if that helps but really shouldn't matter
I'm honestly not sure how it was working for me but I am pretty sure it will work now if you redownload it
