2007-04-08 03:12 AM
2007-04-08 03:55 AM
2007-04-08 04:03 PM
2007-04-08 04:27 PM
2007-04-12 11:35 AM
alroma wrote:The fans usually turn up when there is heat to be taken off.
One more thing. At a certain point in the development of this file, for no particular reason I can place, it seemed like all of a sudden that when performing operations like new sections or rebuilding the 3D window, the processor really cranks up and puts the fans on. Any idea on the cause of such activity?
2007-04-12 03:53 PM
2007-04-16 01:01 PM
alroma wrote:Yes, 3D Window Sections/Elevations and Photorendering all take much more time then regenerating a Floor Plan. In case of each of these it may take considerable time to generate the 3d model (even minutes of larger or more complicated projects). The Open GL capabilities of the graphics card count only when the 3D model is actually generated and you navigate in the 3D Window. So that is completely normal.
Lazlo,
Thanks for taking an interest. I kinda understood the physical reason for it, certainly from the point of view of the computer. I realise, too, that the model data is ramping up as well. I was not specific enough in what I said, I think, as what I was meaning to get at was the fact that it seemed to happen all of a sudden, as if something had changed in the file, something corrupted that is, and that this could be a cause. (I also lost all the data from said file and it reverted to a default file, so something was wrong with it.) I just want to understand all this stuff.
So, generally, should I be surprised that sections and the like are taking finger tapping time to generate? My problem is that this is my very first model in ArchiCAD (in 20 years, that is) and I have nothing to compare with. The model itself is a single house. The only other details I can supply is that it is stuffed with composite sections, complex profiles and SEO operations!
Actually, there is one more thing, which is that on one of the SEO's, which is into a composite floor to take walls down to the slab, a plane of colour shoots out to join nodes together, which of course should not happen, but which annoys and intrigues all at the same time!I would have to see a screen shot of this because I do not quite get it at the moment.
2007-04-21 05:20 PM
