svpribyl
MEP Designer? Modeler? Newbie at using this
I'm using ArchiCAD 28 Technology preview and the first occasion has arisen where I would like to use the MEP tools. There is no separate MEP work environment that I can use. Is there supposed to be a separate WE? What is the best way to learn the workflow and functionality for a MEP Newbie?
Steve Pribyl
MAC OS Sequoia 15.5
ArchiCAD 28
15 Replies 15
bmatt
I‘m sorry for not having a newer tutorial. It is from Graphisoft but it is in German. As Barry told yet : In actual version there are some modifications in usability. But I think you can deal with it.
Bernd
Archicad 29 Collaborate GER | MacOS 26 Tahoe
Spencer Browne
Has there ben any updates related to this, i'm having the same issue where I just got ready to do the MEP map for my model and the environment is missing in AC28.  I'm also on an intel MacBook Pro.
Spencer Browne
I am not a Mac user so I can't confirm if it is just not there on the mac version.
As it comes with the initial install of Archicad, even if Graphisoft fix that it will not help you unless you then re-install.
Just unzip the one I have attached in previous post and import that WE.
Spencer Browne
Thanks Barry I'll give that a try and let you know if it worked.
Spencer Browne
Thanks for the assist this appears to be working and the tables have come along with this environment!!  This was an oversight on GS side, does not make for a happy customer, but im glad the forum was here to give an assist.
