MEP29
Guillermo1
In a piping ssystem can be more than one systems conected? example:residual piping and ventilation piping
i do it with a 3 option, with an custom id for the ventilation pipe and graphic override, but only paint the label not the pipe
5 REPLIES 5
Karel Landa
there are 2 options
1. Create an object that has 2 connections where you can set the MEP system. Then you can connect the routes to it
This object can be created from 2 MEP connections and then saved as a new MEP object
2. If you don't care about imperfection, you can just leave a small gap between them (0,1 units)
From Archicad 17
MacBook Pro M1 Max
Guillermo1
Hello
is there an object like this for mep 29?
There is a flexible pipe tool with which you should be able to do this. A bit clumsy, not as intuitive like the versatile MEP library
From Archicad 17
MacBook Pro M1 Max
Hello Karel , thank you i will try
