Mac OS X 10.5 Leopard and Archicad?
Can anyone from G_soft say anything assuring about AC11 working under the about-to-be-released Mac OS X 10.5 Leopard?
150 Replies 150
Djordje
Everybody,
In order to at least make a semblance of order, I have merged all the topics regarding Archicad and Leopard. Please feel free to post further only here.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
In Leopard isn't possible to install ArchiCAD 9.
There is a problem with the path folder during the installation.
You hate to install into a 10.4 or into a PPC.
Then, copy the ArchiCAD's folder into Leopard.
CU mirco
www.3Dsmile.it
PS there is a bit limitation.
In Leopard, you can Run form ArchiCAD 7 and not from AC 6.5 - 6.0 (if you use the AC application insert into support folder. It's in AC 7 CD installer)
Stress Co_
David wrote:
Stacks is good and bad. There should be a third option for the old way that worked very well for drilling down into your folders.
Ahh, they just fixed this in yesterdays update 10.5.2
Now, .... if they could fix the Dock so that multiple sessions of AC11 would show the running file's name (like it did in Tiger) .... I'd be a happy Camper.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Has anyone else had this:
When trying to print from model view (marquee & cmd+P) it's not possible to set the printing scale by hand - numbers just don't appear to the box when pushing buttons. So if I want to print something in, let's say 1:250 it's possible only by drawing a polyline frame of the exact size, selecting it with marquee and using "scale to fit".
This occurs once in a while. Even restarting computer doesn't help. We haven't had this problem ever before OSX 10.5. We are using Finnish version of AC11.
Dwight
This is not my experience on the USA version - all is well.
Dwight Atkinson
"MudShark" wrote:
When trying to print from model view it's not possible to set the printing scale by hand - numbers just don't appear to the box when pushing buttons.
We have also had this. AC11 1114 AUS and OSX 10.5.2 both Intel and PPC.
I've also found it to come and go, thought i had worked out a pattern, but can't remember now.
If you enter a custom scale the digits go into the number of copies box, One person here wanting a single 1:50 drawing printed 50 copies, and at the wrong scale.. bit of a trap for young players.
I found - at least some kind of - a solution to this:
You can enter the scale, if you press tab for a couple of times.
Makes sense - doesn't it?
Help please
I am a new user of Archicad on Mac
I want to know if u can use multiple instances of archicad on mac os x(Leopard) and how
Thanks
Thomas Holm
Open one project. In that, select Open.. and check Launch a new instance of Archicad
(Edited) Stop (don't open additional instances) when your machine's internal memory (RAM) is getting crowded. It will get very slow otherwise.
Thank you very much
I didn't saw that
