2020-01-15 10:52 PM - last edited on 2023-05-23 06:00 PM by Rubia Torres
2020-01-17 04:53 PM
2020-01-20 02:54 AM
vert{2} 0, 0, -0.02, 1 ! #1 VertId=0 vert{2} 0, 0, 0, 1 ! #2 VertId=0 vert{2} 0, 0.76, -0.02, 1 ! #3 VertId=0 vert{2} 0, 0.76, 0, 1 ! #4 VertId=0 vert{2} 0.76, 0, -0.02, 1 ! #5 VertId=0 vert{2} 0.76, 0, 0, 1 ! #6 VertId=0 vert{2} 0.76, 0.76, -0.02, 1 ! #7 VertId=0 vert{2} 0.76, 0.76, 0, 1 ! #8 VertId=0
AC22-23 AUS 7000 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2020-01-23 04:23 PM
2020-01-28 03:35 AM
kittonian wrote:
Looks like (at least from your attached photo) that it does not work for you either and your panel is overlapping your inner posts.
2020-02-05 09:52 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-27 12:53 PM
kittonian wrote:Hi,
Spent the entire morning trying to figure out what I was doing wrong, only to find that this seems to be a pretty major bug in the railing tool.
Issue:
Associative railings using panels and inner posts do not respect the "left offset from previous post" or any of the offsets for that matter. Nothing changes.
Workaround:
If you draw a static railing, everything works as it should and all offsets are respected.
I had created custom panels and needed to use the offset values in order to line everything up correctly for the staircase. However, with or without custom panels, this bug seems to be rampant. The moment I drew the railing statically everything started working as it should.
Minh Nguyen
GRAPHISOFT
2020-08-10 08:32 PM
2020-08-11 02:17 PM
Tincan561 wrote:Hi,
I am having a similar problem with railings. However I have no workaround. it doesn't matter whether the railing is static or associative, as soon as I turn a corner AC does not recognize "Right Offset from Inner Post". Can someone help me with this?
In the attached png file, both railing have the same settings and a 3" inset for the panel. As soon as I turn a corner the right inset disappears.
Minh Nguyen
GRAPHISOFT
2020-08-11 03:17 PM
