2017-01-30
02:38 PM
2023-05-23
04:16 PM
Rubia Torres
2017-01-30 03:33 PM
2017-01-30 07:25 PM
ejrolon wrote:Thanks. I did as you say, but then when I put it in my layout sheet the trace reference worksheet doesn't´t appear visible.
That can already be achieved by not exploding the DWG once you have imported it or by not using the Open command to "import" the DWG in AC.
The correct procedure is:
• Open a new or current AC File
• Create a Worksheet
• in the WS go File->External Content -> Place External Drawing
• After placing select the DWG, crop it to the relevant area you need and use CMD+T (CTR+T Windows) to change its Pen Settings and Edit what Layers you need visible.
• Once you have locate the DWG in the correct place then you can use Trace Reference to snap to its intersections. Since the DWG is not exploded you will not get any extra Layers or cruft from the file
2017-01-30 07:57 PM
2017-01-30 09:26 PM
ejrolon wrote:I think you mas understood me.
You don't trace it in Layouts
Except for some few items Layouts are only used to place Saved Views, never to Draw anything.
You can Trace the DWG either in Plan or in another WorkSheet and then place that in your Layout.
2017-01-30 10:05 PM
