Making 3D mesh - please help
Hi everyone.
Is possible to make 3d mesh from this file?:
http://dl.dropbox.com/u/67741662/ales-1.dwg
I dont know how to do it
Is there any tutorial on web?
Thanks for help!
13 REPLIES 13
It's quite simple.
1. You need a ".lsp" add-on for AutoCAD (or other compatible CAD program with a support for AutoLISP). Load the add-on, run it and export 3D points to a .toc file. Next rename that .toc file to .txt file and open it in the Notepad. Delete all points without a "z" values, then save.
2. In ArchiCAD use menu Design > Place Mesh from Surveyors data...., select Placement and Project Zero > OK.
3. You got the Mesh!
This is a picture of the mesh from ales-1.dwg!
And this is the add-on:
andro can you please send me archicad file of that mesh? i dont have CAD program
Download this .zip (ales-1_3D points geo.txt) to make the mesh yourself in ArchiCAD (start at point "2" -Place Mesh...)!
Any other solution if I only have ArchiCAD 16?
Assuming that I have AutoCAD, how can I load the add-on?
1. Attach the .dxf file. I will open it and export the 3D points.
2a. LOAD....type this in Command line: appload export_survey_3D_points
2b. RUN......type izvozgeod+Enter
Thank you very much. Let me find a computer with AutoCAD this weekend and give a try.
Would it work for AutoCAD on Mac?
Sorry, I don“t know.
I will give a try and afterwards I will leave a feedback.
And again, thanks.
