Making hole in vertical slab, why is it so complicated
cocoloco
I know this has been posted countless times, but none of the suggested resolutions seem to work for me (MacBook user).
I’m trying to create very ***simple***  hole or cutout shape in a slab (elevation), but Archicad won’t allow it. I’ve tried both 2D and 3D approaches — first by drawing, but that produces odd, distorted shapes that are very difficult to manage (sweet Revit). I also expected to be able to “subtract from polygon,” but that option isn’t even available for vertical slabs for some reason. And adding an opening to a slab feels like a mission on its own completely ignoring measurements I set up making full hole instead of just the size I made...
Honestly, the software’s interface really needs a major upgrade, especially considering its pricing.
MacBook Pro, Sonoma: 2.6 GHz 6-Core Intel Core i7, Intel 16GB mem,
Archicad Solo 26 and 27 (in testing mode)
6 REPLIES 6
Emre Senoglu
This is a workaround, and it might have been suggested before but here it goes:
-Create a beam in 3d, change its shape as desired (round, rectangular, custom profile).
-Assign 'Air Space' material for its structure.
-Go into Building Materials settings, find 'Air Space'. Crank up the Intersection Priority to 999
-Position it as desired.
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
runxel
Hero
Sorry, what is a vertical slab? 😁
You mean.... a wall?
Hahaha you made me laugh. 😆 But no I mean actually slab (built vertically) I mean it’s a fireplace face (marble slab) so i didn’t want to call it a wall.
Personally, I would use a wall and place an empty opening window in it or use the opening tool.
Or you could use a tall skinny slab and still use the opening tool.
If you do it in 3D, you can place a horizontal opening with the opening tool.
I tried the opening. It worked yesterday but sometimes it’s so glitchy and won’t do the hole at all or follow the shape.
I also tried to do irregular hole by drawing and using the magic wand but no luck at all.
I agree.
It took me some years to overcome the name of the elements and use them based on the design properties and the geometry needs of each case.
If a "slab" performs better than a "wall" in certain case I would use a slab.
Maybe you can use a shell and make a shell hole......
The name does not matter. Sometimes I use something based on the quantity extraction options.
Botonis Botonakis
Civil Engineer, Enviromental Design MSc., BIM Manager for BS ArhitectsVR
Company or personal website
Archicad 27. Windows 11. Intel Xeon 2699x2,64 GB RAM, Nvidia 3080Ti. 2 Monitors.
