Manual Inputs - Drafting
For some reason, I have lost the ability to manually input the radius when drawing an element (be it a wall, line, or other). Example - I want to draw a line, I select the line tool, click a first time ...then I hit "R", but it does not revert to the "R" box down low, and I can't manually input a value. The "X", "Y" and "A" all seem to be working, but can't get the "R" back in operation.
Any suggestions?
Mahalo,
Patrick
5 Replies 5
Are you on AC11? Try turning Tracker on (although with it off R still works for me), or use D (distance) instead.
In AC 9.0. There is no "D" functionality ...well, that I know after trying it.
Link
ArchiCAD 9??
We're up to AC11 now, so excuse the confusion.
Chances are that the keyboard shortcut has been detached or reassigned to another command. You can check/reassign it under Options> Work Environment. See the attached image.
Mahalo,
Link.
Thanks Link! You nailed it!! ...and big MAHALO for taking the time to illustrate ...I had dabbled with another function a while ago and had probably utilised the "R" for some "Rebuild" functionnality.
As for AC version, hear 12 is just around the corner ...BTW, anyone with inputs of compatibility of 11 with Vista? ...though I am sure a little research should yield the info... Any personal inputs welcome!...
Again, MAHALO!!
Patrick
Again, MAHALO!!
Patrick
ArchiCAD 11 is officially supported on Vista by GS. Previous versions are not.
http://www.archicadwiki.com/ArchiCAD_versions
