2 weeks ago - last edited 2 weeks ago by Laszlo Nagy
Hello
In Archicad, the measurement unit of the dimension lines is centimeter, but in my master sheet these measurement units are converted to meters. How can I show them as centimeters?
Operating system used: Windows 11 24H2
Solved! Go to Solution.
2 weeks ago
You need to create a new dimensioning type. Go to Options - Project preferences Dimensions
There you can set everything up as you want them to have, and then, you can Store them with your own naming.
ex:
This can be accessed by the menu you showed in your screenshot.
Hi!
You can try going to Options - Project preferences - working units:
edit: I now understood your question: Check the placed view from the view map (right click on it and go to settings) and view check the dimensioning settings
2 weeks ago
yes i checked here but only meters and millimeters are available. there is no option to convert to centimeters. how can i do that?
2 weeks ago
ex:
2 weeks ago
Thank you very much, I solved the problem thanks to you
2 weeks ago
Glad I could help!
