Material fill in plan
I'm pretty sure that I must be missing something fairly simple/obvious but google searches aren't helping.
How do I set and show a material fill for various elements in plan?
E.g. I have a grass material for a slab, which shows green in 3D and I'd like it to show green in plan.
I can individually set the colour of slabs but I'd like it controlled by the material
8 REPLIES 8
alemanda
Set a cover fill. It works for slabs, meshes, roofs, morphs, shells.
Or you can manually draw a fill on the element.
AC27 latest hotfix
Win 10 Pro 64bit
Double XEON 14 CORES (tot 28 physical cores)
32GB RAM - SSD 256GB - Nvidia Quadro K620
Display DELL 25'' 2560x1440
www.almadw.it
Thanks for your reply but I want to control it via the material i.e. everything in plan with a certain material (and no overrides) has a certain appearance.
alemanda
Ok ...
so in the surfaces you have to set the fill and activate the fill by surface in the settings of the element
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Thanks alemanda but I'm still struggling!
I created a material, with 'paving Asphalt dark' for the surface but it shows up as blue/purple in plan!
alemanda
Ok. I attach the screen shot ... it's in Italian but I think you can get the info you need ...
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
Thanks for your continued assistance, not sure where I'm going wrong, please see attached
Other attachment (limited to 1)
alemanda
it's right.
be sure that in MVO (Model View Options) the cover fills are not override
AC27 latest hotfix
Win 10 Pro 64bit
www.almadw.it
