Measuring Morph
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2016-05-29 08:14 PM - last edited on 2023-05-23 04:18 PM by Rubia Torres
2016-05-29
08:14 PM
[/img]
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-05-30 12:49 AM
2016-05-30
12:49 AM
• go to 3D View
• Use Look To Perpendicular Command and click on Face
• Right Click and select "New 3D Document"
• Dimension on 3D Doc Window
It might be easier to "explode" the Morph so that you have individual faces/
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
AC27 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-05-30 01:36 AM
2016-05-30
01:36 AM
Eduardo Thanks for your advise. Tried what you suggested and it worked perfectly until de measuring part, the Dimension tool is not working properly on the 3D Document created, i can't get it to be aligned with the measured face of the Morph
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-05-30 01:40 AM
2016-05-30
01:40 AM
Then create a New Detail using the detail tool (or you can use Worksheet too) based on the 3D Doc and dimension there it should be easier. Also always verify that the actual dimensions for the detail and what is measured in the Morph match.
AC27 US/INT -> AC08
AC27 US/INT -> AC08
another Moderator
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2016-05-30 02:23 AM
2016-05-30
02:23 AM
Eduardo, Thanks again, with the Detail tool worked perfectly.
I found another way wich is creating a Fill using the magic wand on the 3D document image and then Copy/pasting it on the floor plan view. This way i can manage all the pieces to measure then and even create a DXF file to send to the CNC plotter.
