We value your input!
Mesh - Vectorial hatch patterns
Are any of the users out there using any Vectorial hatch patterns on their site Meshes?
And if so what fill Pattern?
Are your views (or Layout drawings) of sections or 3D slow to generate?
This question is dure to a problem that I am having which is discussed here.
Hello Jay,
I usually don't use a material with a vectorial hatch on the
mesh skirt but I tried it in a project to see if it would cause the
problem you describe. I changed the skirt material from
earth to Ls earth which has a vectorial hatch associated
with it but I did not get the warnings you describe.
Peter Devlin
How about a Stone Texture on the Top Material?
Hello Jay,
I took a mesh that covered about 57,0000 sq ft that had
32 contours and made a material using paint-02 and
adding Stone Surface vectorial hatch and assigned it
to the mesh upper surface.
It took about eight minutes to process in the layout
but I got no errors. With the type of errors you are
getting it could be that the file is corrupt.
Peter Devlin
