Gail wrote:
That seems to do the trick. I had tried changing the vectorial hatching but not the texture. It seems LS-Grass Green was the one causing the trouble. Thanks.
Glad that solved things for you, Gail.
A general comment to any readers who are new to ArchiCAD is to note that Materials are not just for rendering, even though we usually think of them as being the 'home' of photographic texture maps and related settings. Materials also contain a Fill reference (to a fill defined under the Fills attribute settings)... which is used when 'vectorial hatching' is enabled for section/elevation ... and even in 3D line drawings (with the internal engine).
So, new users who may have no intention of generating renderings, will still want to look at Materials in terms of applying fills (hatches) to sections/elevations and 3D drawings.
Here is a tip related to using custom fills with materials associated with the siding of a home:
http://www.visualmotion.com/tip2006-04.htm
This is a very unique (atypical) and somewhat advanced application of custom fills, alignment, etc - but emphasizes this 'other' use of Materials.
(Has little to do with Gail's question...just a tangent here.)
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
