2011-06-08
02:23 AM
2023-05-25
05:04 PM
Rubia Torres
2011-06-08 02:44 AM
2011-06-08 03:29 AM
2011-06-08 03:29 AM
wayneh wrote:
Hi this is my little reminder list for the Office
1) Use mesh tool to draw a mesh around the perimeter of your site
2) Use space bar and spline / p-line tool to draw contour lines from survey dwg (Making sure that the contour lines go beyond the Boundary Line)
3) Whilst in mesh tool hold space bar and click on selected contour to add it to the mesh ( select add all ridges in little dialogue box )
4) 4 - Right click on a contour node and select the 'z' value icon and asign the rl you want to the contour (select assign to all in dialogue box)
5) 5 - Ensure you manually select the two endpoints of the contour and change the RL individually ensuring assign to all is not selected as it will assign the value to the whole perimeter of the mesh
2011-06-08 03:33 AM
Barry wrote:Someone at work showed me this way. Is there a easier way?
What Wayne said will help you add contours to a mesh and alter its topography.
But if you want to generate contours from an existing mesh try this.
http://archicad-talk.graphisoft.com/viewtopic.php?p=177385&highlight=contour#177385
2011-06-10 06:24 AM
2011-06-10 07:30 AM
2011-06-11 07:10 AM
2013-07-03 03:14 AM
