Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Meshes - how best to "trim" them to an edge??
rob2218
here's the deal:
I have one mesh with contours which I need to have dissected into two.
one to show "asphalt" as the material, the other to show "grass" as the material.
How do you "trim" to a line meshes?? so you can keep one half of one and the other half of the other copy?
thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Erich
If your line is straight, as it appears to be, you should look into the split command.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Another solution would be SEO with intersection... This way you could keep the integrity of the mesh... and make your terrain editing way easier.
HTH.
Paulo
