Middle mouse button - Orbit and Pan
Is there any way to reverse the way it works? So that middle mouse will orbit and holding [shift] will pan?
I can't find any options in the options to do with mouse clicks.
4 Replies 4
Erwin Edel
Try Options > Work Enivornment > Input Constraints and Guides
There are two settings for the wheel with regards to pan and zoom.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Yea found that (after going through /every/ setting) - don't seem to actually do anything - I've tried both and can't see any difference in the way it works.
Erwin Edel
Outside ArchiCAD you might be able to find some mouse button mapping software to reconfigure the way it works.
www.leloup.nl
same problem, i can't understand only in laptops?
