ā2005-02-26
03:14 PM
ā2023-05-25
06:21 PM
Rubia Torres
ā2005-05-12 05:47 AM
ā2005-05-12 09:51 PM
ā2005-10-26 03:36 AM
ā2005-10-26 04:17 AM
ā2005-10-26 06:16 PM
ā2005-10-26 07:54 PM
ā2005-10-26 08:31 PM
Jay wrote:Jay: use the new SE 9 library. Graphisoft has not done a great job of communicating with the US user community about this library, which they have invested quite a bit of effort into improving.
I have not seen much "nah-say" discussion on the Special Edition Library, but I think that the release of a Library that does not work with Existing Projects is Unacceptable. I would not use the Special Edition Library.
Also If you start using this Library for all new projects, will these projects convert over smoothly to AC 10 and the associated Object library PLA.Yes, the SE9 library may be thought of as the pre-10 library. The US AC 10 library will simply be the evolution of this library.
And if the conversion is "smooth" from the Special Edition Library, does that mean that us that have stayed with the "default" Object Library for AC 9, will then be "forced" update all our "old" projects manually to the new AC 10 Library.No more so than when you moved from 8.1 to 9. If you want to continue to use old library parts and not take advantage of new features and bug fixes, that is a choice.
Hoping the Library Transition from AC 9 to AC 10 works as smoothly as AC 8.1 to AC9. So I am a little leary of using the AC 9 Special Edition Library.No reason whatsoever to be leary. It behaves as all other libraries did and do, and it is what the AC 10 library (US version) will be based on, so it is your first step to conversion.
ā2005-10-26 09:33 PM
Karl wrote:
... use the new SE 9 library. Graphisoft has not done a great job of communicating with the US user community about this library, which they have invested quite a bit of effort into improving.
ā2005-10-26 09:53 PM
Sergio wrote:9_SE is a new library with all of the same objects as 9_US, with some dramatic changes to some of them. The 9_SE, like Karl mentioned, is more like a Archicad pre-release 10 library than it is an Archicad 9 library.
This is encouraging finally. The only think that _I_ still need clarifications on, is on what the difference between the 9_US and 9_SE is. Why are there two separate ones, and which one should be used? They seem to have the same blocks in both libraries and I think that's the confusing part, at least for me. I'd much rather have less blocks loaded up than 10 full libraries with only a handful of useful blocks, which tend to slow down the computer process power.
ā2005-10-27 01:10 AM
