I'm in Tara's office too, and this one is really weird.
On Tara's Mac, I've now done the following all with the same behavior:
I've opened a new project from the AC 10 template, from GPA(that's us.) project Settings, and GPA Drafts.
I tried loading the AC9SE.lcf individually from both the server (PC) and the Mac's hard drive, AC 9 wd internal Doors deliver an error in expression from the master script of the door, line 15. The pull-down menus on the library parts are also not working. (if you look at line 15, there is no error in expression. Laszlo is right about the expression going from string to number. If it were my part, I'd joyfully de-bug it.)
The doors were working fine a few days ago, so I am wondering if there are any MAC users out there who accidently changed some setting that produced this similar behavior.
What I find really strange, is that it is only a few of the doors that re not working. I'm sure other parts make the string to number conversion so why are only the doors affected.
We tried restarting a couple times, which did nothing.
Any last suggestions before we uninstall and reinstall AC10? (which I've already been told by a true wizard will most likely do nothing to fix our problem)
Thanks.
