Missing Attributes
Hi All:
Working in 19. I have missing attributes in a number of objects, ranging from windows to morphs (per find and select). When I click into one of these objects, I can't seem to find the missing attribute—morphs don't have many attributes anyway. Any idea where else to look?
13 REPLIES 13
Further, nothing is missing in the Library Loading Report...
And some more information:
1. The missing attributes are in objects that have different Building Materials.
2. I tried copying and pasting out of this file and into a default new file and it still says missing attributes in find & select.
3. Objects were copied and pasted from a version 18 file originally.
You may need to show us an example.
What exactly is the missing attribute?
I have no idea what the missing attribute is. Using find and select, I can pick all the objects that contain SOME missing attribute. How does one find out what is missing?
A report will be generated when you open the file.
In the Library Manager they can be seen like this -
Yes, there is nothing listed as missing in Library Loading Report
Screen capture:
Library Manager:
A bit more:
Find and select is telling me attributes are missing from marker objects (including interior elevation and detail).
Could this possibly be a bug in find and select?
