2007-11-14 01:00 PM
2007-11-14 04:27 PM
2007-11-15 12:11 AM
2007-11-15 07:34 AM
2007-11-15 08:35 AM
2007-11-15 09:28 AM
mc0m wrote:I would advise against deleting or overwriting fills and materials in any of the Options> Element Attributes submenus.
Link,
When you say they should be left alone, do you mean to not make any adjustment such as line weight or pen color to existing fills?
I was looking at fills today and noticed that you could change fill attributes in the attributes dialog and also in the object menu (Im not sure if that's the right word for it). Are you saying to leave the settings in the attributes alone?
2007-11-15 12:31 PM
2007-11-22 05:59 AM
2007-11-22 10:28 PM
Rex wrote:Well I did suggest that...
Link, I don't think it's feasible to start with a "New and Reset" when you already have a template system in place. It might be better to import the fills (or other 'butes) from a file that was started by New and Reset by deleting all fills (but one as you have to keep one fill) in the attribute manager, and THEN overwriting as it will overwrite the one fill and add all of the others with their original index number.
Link wrote:It looks like AC11 is much less risky with it's attribute management and hard coded fills, than previous versions. So for people who have developed a template, deleting & overwriting attributes may not be such a danger. But they will still lose any attributes they have made, so an analysis is still necessary before and after any 'merging'.
You could try saving a New & Reset and overwriting the fills and materials into your existing file, but because of some hard-coded fills, this is not 100% risk free. If you do it this way be sure to analyze (ie. Print to File) the attributes in each file and compare before and after the merge.
