Missing SEo in Linked Module
I tried to do a search for this but no luck. I recall this being discussed recently.
I have a Module file (Site Plan) that is Linked to another PLN file. Previous to (I believe) the 2219 Patch the SEO operations within the Module file remained, now the SEO in the Linked module file is lost.
While I was typing this message a performed a check....
I re -saved the Module file with the previously Hidden SEO operator. Updated the Module file and the SEO now is remaining. This makes sense that the SEO operator be in the linked module file, but I do not recall having to do this before.......
Oh well, all is fixed now and this is my 500th post so maybe I am a veteran now.
Yes the operators must be included in the module to work. It has always been this way. You probably did it before without realizing it. Perhaps the operators were on visible layers.
Congrats on the veteran status. After a mere 500 more posts you will join the exclusive Senior Members Club. The limo service is a bit spotty but the health club facilities are terrific.
