Missing slab and landscape issues
Michka
Please help I have a drawing I have been working on involving landscaping that I need to render in 3d. Today I inserted extra 3d trees to make things look more realistic but when I have gone into 3d the slab has become wire frame see-through. The slab is definitely still there and I haven’t changed any properties of the slab but it’s only got a wire frame around it. This is the first time I have used this amount of trees in 3d.
I have worked out my computer is having video / graphic card issues so would this be why this is happening?
Also what would be the best way to do 3d landscaping using archicad 27 or in conjunction with archicad 27 without things crashing and causing problems?
CosminF
Is the slab on a separate layer? If so, maybe you have accidentally made it display as a wireframe layer.
further info:
https://help.graphisoft.com/AC/27/INT/#t=_AC27_Help%2F025_Attributes%2F025_Attributes-4.htm%23XREF_1...
AC 27, running on Windows 10 Intel(R) Core(TM) i7-9700K CPU64, 3.60GHz, 16GB RAM, Nvidia GeForce GTX1650
Unfortunately this didn’t work. But thanks for trying
