2007-03-07
10:18 PM
2023-05-25
05:57 PM
Rubia Torres
2007-03-12 03:35 PM
Scott wrote:
Shown in the attached image is a side by side ...
2007-03-12 03:43 PM
2007-03-12 05:34 PM
Mike wrote:Mike, yes that is exactly the typical procedure which is followed. After defining a view set (settings), it is dragged onto an open layout sheet. It has always worked fine, except with this model view option combination and this fill. I will see if the behavior is different using other fills. Not the end of the world, just unexpected.
I wasn't clear from your post, but are you first saving a view that is tied to the model view option you created and then placing that view on the layout?
