dcerezo
Modeling an Encroachment Plane
Hey all,
In Los Angeles, single family lots have what is a called an Encroachment Plane superimposed on the buildable volume that you can put a house in. It starts at grade, goes up 20ft, then angles at 45 degrees until you hit height limit. On a flat lot this is easy to model and whenever I cut a section I can quickly see if my house is exceeding this imaginary boundary.
However, I now have a hillside lot to contend with. The grade changes constantly, even from one side of the lot to the other. It would be very convenient if I could model this 45 degree plane that follows the hillside from 20ft to height limit.
Does anyone have any idea how I could model this? See attached image for what I mean.
I was thinking like some sort of mesh that spans two splines, but I'm not sure what I'm doing.
Thanks in advance!
ArchiCAD 26 - iMac 27, Late 2019, 3.7 GHz Intel Core i5, 32GB Ram, Radeon Pro 8GB, macOS Sonoma
3 Replies 3
Aaron Bourgoin
perhaps you could use the Mesh to Roof Goody to create roof planes from your site mesh, edit or simplify the resulting roofs and elevate them.?
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.0 USA
Rhino 8.33 Mac
MacOS Tahoe 26.5.2
If it is level side to side (and a constant width) then you could use the railing tool.
Create a custom profile rail the shape of that envelope.
Then place the rail along one side of your site.
If you crate a contour line on the mesh, you can even just magic wand it to that line.
Or there has been work done on a polyline profile object.
Maybe this can help (not sure), but again I think the profile has to be a constant size/shape as it follows the path.
https://archicad-talk.graphisoft.com/viewtopic.php?f=49&t=69913
And assign a transparent building material to the Profile Barry is referring to so it will not hide other elements in 3D when you view it.
