Each individual slice could be made as a complex profile wall.
The complex profile would give the shape of the wall and the length of the complex profile wall would be the thickness 0f the wall (slice).
So each slice or panel would be a very sort length wall using the profile you define in the complex profile.
Or you could use the morph tool.
You would still need to give the morph the shape of each slice and then extrude it to the thickness you need for that slice/panel.
The column design would be just one wall/morph rotated and multiplied at the same time.
