2008-10-28
01:41 PM
- last edited on
2023-05-23
03:07 PM
by
Rubia Torres
2008-10-28 03:51 PM
2008-10-28 04:13 PM
2008-10-28 04:55 PM
2008-10-28 05:41 PM
malte wrote:Yes, complex profile and beam tool is the way to go for coping stones. You may notice that both ends of a beam remain vertical regardless of the sloping angle which may not be correct. Another SEO can be used to square off the end if necessary, but it can get a bit messy.
...The wall does actually have a coping stone running along the top which I could model using complex profile and the beam tool? I would then duplicate the coping and put one on a special layer - operator layer. Again hidden on all output formats. Would you put all your operator elements in the model on the same layer. So on a 'operator layer'?..
2008-10-28 07:39 PM
malte wrote:Operator elements only need to be hidden when you don't want to see them.
Thanks for the quick reply. The wall does actually have a coping stone running along the top which I could model using complex profile and the beam tool? I would then duplicate the coping and put one on a special layer - operator layer. Again hidden on all output formats. Would you put all your operator elements in the model on the same layer. So on a 'operator layer'?
