ā2014-10-03
07:02 AM
ā2023-05-25
04:59 PM
Rubia Torres
ā2014-10-05 11:37 AM
Nuge wrote:That is a very interesting idea! Could certainly save a lot of memory.
if you are using octane render why dont you create a displacement map and apply it to the meshes (use a gradient to get the curve looking right)
Nuge
ā2014-10-05 10:03 PM
ā2014-10-05 10:49 PM
another Moderator
ā2014-10-05 10:52 PM
ā2014-10-05 10:53 PM
ā2014-10-06 12:15 AM
ejrolon wrote:Thanks for that Erjrolon.
With a little effort I was able to do this using complex profiles and morphs. Is it close enough?
⢠For an intersection you will need to split the road at logical points that you can control. To create the camber on the road on the curve you will need to do some extra steps but they are not that difficult.
⢠BTW AC is not made to do thisā¦
ā2014-10-06 12:34 AM
another Moderator
ā2014-10-06 01:24 AM
ejrolon wrote:Hi thanks again Ejrolon. - the trick is that there are no straight changes in width - all follow curves.. and trying to join a morph to a mesh without visible seams will be a nightmare...
I know that straight change in width can be accomplished with the Shell tool using the Ruled Surface Option. So you might explore on how to model the two streets But a 4 way curved intersection will require a lot of planning on how to build the individual segments. In one case I did a combination of Morphs and Meshes to achieve some of the transitions.
⢠So my workflow for this would be:
1. Define specific ridges on the streets and simplify the ridges as much as possible.
2. Draw the Ridge using the Morph tool to have points to snap to.
3. Used ruled surfaces for sections that change width or merge
4. Use Complex Profiles converted to Morphs for simple curves or straight elements that elevate.
5. Use Complex Profiles applied to Beams or Walls for straight sections.
6. For the Big intersections then I would try a mesh.
But still AC is not a good tool for this
ā2014-10-06 01:38 AM
ā2014-10-06 01:39 PM
another Moderator
