Learn more
Lingwisyer
Guru
Modify Morph Triangulation
Hi all,
While attempting to create a curved form with the Morph Tool I have run into an issue with the edges used in the subsurface triangulation and I have had no success in trying to modify it...
I am wanting change the subsurface triangulation to be between the red lines rather than that blue. Thoughts on how to change it? I tried deleting the the offending line and adding the new ones but have been unable to get it to create faces...
Ling.
4 Replies 4
Lingwisyer
Guru
I appear to be able to create new faces one triangle at a time... select edges, cover with faces. Selecting multiple edges of neighbouring triangles returns an error about not having any "free edges or faces"...
Carstenem
Can you let us know what you like to draw/model, I have a feeling there is a better way to what you like to achieve.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Lingwisyer
Guru
It is a canvas stretched over offset circles that reduce in elevation to an off centre central pillar, so I have a changing double curve.
That is what I have managed to get which is good enough for my purpose.
Ling.
Carstenem
right ! Nice
Carsten
www.asmtechbase.com
