Modify Wall Reference Line
Where do I find this? According to help, its default location is under Edit, but I can't seem to find it or locate it in the Work Environment to add to the Edit commands.
Need to switch reference lines without moving the wall.
thanks!
Need to update profile, now on 18
DGSketcher
Legend
Go to Edit > Reference line and Plane > Modify wall reference line
Dontknow
With image:
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Thank you for your detailed reply!
I found my problem. When I upgraded to 18, I carried forward my custom Command Layout Schemes and when I did that the new Modify Reference Wall Line command was not visible anywhere. In Work Environment I couldn't even find it under Edit to add to my Toolbars. I had to apply the AC 18 Standard Command Layout Scheme before it would even show up.
I've made this mistake in the past when new tools have been added to AC. Something to remember.
