‎2013-04-15
03:22 PM
‎2023-05-23
02:36 PM
Rubia Torres
‎2013-04-15 03:31 PM
‎2013-04-15 03:43 PM
‎2013-04-15 05:12 PM
‎2013-04-15 07:18 PM
‎2013-04-17 09:30 AM
WALtd wrote:I am wondering if the Home Story of the SEO operator and target are the same so they both get saved into the same Module. I figure since it is an associatie relationship they both must be present. But I can imagine that if the Home Story of both are not the same then one may get saved into a Module, the other may not. Then the SEO cannot be maintained when that Module is inserted since one of the participating geometries is missing.
I have a straight forward house modelled in a separate file and then saved as a Module file to bring into the main site model.
I have saved each floor separately because the main file has different storey heights for the proposed buildings and this house is existing and will stay un-touched so no need to change this once drawn up.
However when you use separate files for each floor, when you bring them in the solid element operations of the roof have been lost.
Is there any way to stop this from happening?
Because its a module it will not let me re apply the SEO!
‎2013-04-17 02:01 PM
