Learn more
Tom Krowka
Module madness!
I have a building, three stories, that I inserting as module on a big site .pln. There are pieces of trimmed walls that stick out through the roof that do not show up in the .pln drawing. XX!!#$@##$%$@!!!
Layer settings are the same, etc.
Any suggestions there?
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
4 Replies 4
give this a shot.....check off the adjust module angle
Tom,
Sounds like you've used SEO's to trim the walls to roofs...SEO's don't work with multistory modules when the roofs and the target walls are on different stories.
HTH,
Dan K
Tom Krowka
Dan:
Tom,
This question is not directed to you.......
WHY THE ##@!$$#@%&^% NOT
Thomas@wkarchwk.com
www.walshkrowka.com
TomWaltz
How nice life would be if modules could use SEOs and have their own Element ID's....
Tom Waltz
