2008-12-05
08:47 PM
2023-05-23
03:06 PM
Rubia Torres
2008-12-05 09:06 PM
2008-12-06 08:13 AM
fabricfo wrote:Place the beams in the appropriate storey (roof plan). In the 3D window, edit the hotspots bu dragging them up or down, thereby changing the slope of the beam. They also join correctly.
I tried to create a molding (profile) that could follow the lines of the roofs using the beam. But didn't find a way to do that.. The gravity tool by the roof didn't worked ... Someone have a cleaver way to do this?
It's something like the picture below...
2008-12-06 07:07 PM
2008-12-06 07:21 PM
fabricfo wrote:Check which of the icons on the pet palette you use.
Thanks Djordje,
I was trying to make the modification on the section view![]()
But the fusion isn't perfect in this case ( with the other part of the beam straight )... and the hotspot of the below part of the beam isn't editable... is there a way to solve this without using the SEO?
Thanks
2008-12-06 07:43 PM
2008-12-06 08:22 PM
