Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Morph Tool - lost ability to extrude?
rob2218
so...a fellow co-worker supervisor who uses Archicad extensively has lost the ability to pull/stretch/push the 'morph object' he created.
What could be the cause of this?
it works on "some PLN files", it doesn't work on others.
What variant causes this to occur?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
Has he accidentally activated the View\On-Screen View Options\Hidden Morph Geometry toggle?
I also found the below post which explain another cause.
So, basically, here is what can happen:
You are in the 3D Window Settings Dialog, switch to Internal Engine mode and change the Shaded Mode field to "Raster". Then you switch the 3D Engine field back to OpenGL.
The Shaded Mode field becomes greyed since it does not apply in case of OpenGL. However, it is still set to "Raster" and the result is that you cannot edit the Morph with the Pet Palette commands when you click a general face of the Morph. It still works if you click on Morph edges or nodes.
To bring back face editing commands, you have to switch to Internal Engine, set the Shaded Mode field back to "Analytic", then set the Engine back to OpenGL. Then suddenly you are able to edit Morph faces again:
http://archicad-talk.graphisoft.com/viewtopic.php?t=40009&postdays=0&postorder=asc&&start=10
I think this is a bug: ArchiCAD still takes into consideration the value of the Shading Mode field even when you use OpenGL. It should not, it should assume it is set to "Analytic".
Marton Kiss
I completely agree, documented the bug for the dev folks. Thanks all for bringing this up.
Marton
Marton Kiss
VP, Product Success
GRAPHISOFT
