2014-07-0906:22 PM - last edited on 2023-05-2304:25 PM by Rubia Torres
2014-07-0906:22 PM
Hi Archicad people,
I have been using the morph tool lately and found it really handy and it helps to create what I want. Sadly I have not yet fully mastered the tool. I am having difficulty to apply separate textures on separate faces of the morph object because I cannot selected individual faces and can only select the whole thing!
______
For example this is my kitchen area and I want to make the inside a different colour/texture. How do I select the face separately or do I have to draw another 2d Morph and boolean onto it as a new texture?
______
Another example is this resting place inside the wall. I want to make the inside white. Also what tool do I have to use to insert lights on ceilings?
______
Here I accidentally created a node is there a away to remove it?
_____
P.S. Is there a limited amount of questions I'm allowed to ask?
Select a face by pressing ctrl-shift and clicking on the face. Then mouse down and use the top-right pet palette button to change the surface appearance of that face.
To insert lights, you use the Lamp Tool
To get rid of an extra node, you do was with all polygon tools: select the node and move it on top of another node.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
