You can do that in two ways:
1- Using the magic wand.
Yep, but the trick is to
make the path (morph line) a face, that is: you have to close the line, then it creates a face for it.
Now select your profile, use the Tube option in the pet palette, and space-click for magic wand on the surface generated by he path.
Notice that this will add a undesired profile at the bottom, you cut that off ( SEO or just Split)
2- Using the Tube Manually.
Here the trick is to click somewhere in the profile morph, click the Tube command, then re-position the origin of the Tube by clicking on the same plane of the profile morph right where both profile and path are touching.
Then you can follow the path hotspot by hotspot.
It helps if you have made both the profile morph and the path morph a one single morph ( using Union) if you do that it follows the path more naturally.
Hope this helps
Nando Mogollon
Director @ BuilDigital
[email protected]Using, Archicad Latest AU and INT. Revit Latest (have to keep comparing notes)
More and more... IFC.js, IFCOpenShell
All things Solibri and BIMCollab
