ā2005-06-25 01:48 AM
ā2005-06-25 04:49 AM
johncassel wrote:because you use the parallel/perpendicular constraints 'on-the-fly' i guess . . . this has the same affect as setting the custom constraint in the preferences.
Why does this happen?
ā2005-06-25 05:08 AM
~/archiben wrote:How can I control/invoke this "feature"? How can I turn it off so that it does not pick up angles on the fly?
~/archiben wrote:It bothers me because it picks up arbitrary angles on the fly that I do not want to constraint to when I hold down the shift key.
how come it bothers you that much?
ā2005-06-27 04:11 AM
johncassel wrote:Unfortunately this "feature" can't be turned off permanently.~/archiben wrote:How can I control/invoke this "feature"? How can I turn it off so that it does not pick up angles on the fly?
I use the Shift key to control the constraints but I do not want to pick up an arbitrary constraint "on the fly". How can I turn of the "feature" that picks up an angle for constraint "on the fly"?
Thank you,
John
ā2005-06-27 04:51 AM
ā2005-06-28 08:51 PM
