2017-05-13 01:12 PM - last edited on 2023-05-24 08:31 AM by Rubia Torres
2017-05-13 02:20 PM
2017-05-13 03:19 PM
David wrote:Indeed; that does work;), but:
famadorian:
This can be done by using the Marquee tool. Use the Marquee to entirely surround the main Wall, including the ends of the 90˚ Walls. Then use the Stretch command to move the main Wall and stretch the 90˚ Walls at the same time.
2017-05-14 02:32 PM
famadorian wrote:Use numeric input for the operation, as described here: wall how to specified distance from another, the walls will be moved/stretched the specified distance.David wrote:Indeed; that does work;), but:
famadorian:
I don't see the selection/wall when I move the marquee. This makes it impossible to know how far wall A is from wall B.
Any pointers there?;)
