Mulitple Group Edit
Is there any way to create a group, copy it multiple times, then edit only one instance, with the result being that all instances of the group change or are updated? I know Revit has a similar function to what I am describing, but I need to know if Archicad 17 has it too? And Hotlinking is not what I had in mind.
Thanks all !
5 Replies 5
Erwin Edel
Still hotlinked modules do excactly what you describe.
Select module, edit it, save changes and update modules.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Yes, but I have read that hot linked files only show floor plans - I can't use sections or elevations with them. Or so i understood?
You can do anything you like with modules, you can make sections on them, you can make elevations, you can copy, move, rotate them...Anything you like BUT
You must use one instance of archicad to edit module and second to work on your project !
i hope this helps
Eduardo Rolon
Hotlinked modules can contain 2d and 3D objects, walls, slabs, door, windows, dimensions, lines, etc.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thank you all for the help! I'll try out the hotline function then.
