2005-03-09
06:36 PM
- last edited on
2023-05-25
06:02 PM
by
Rubia Torres
2005-03-09 06:56 PM
2005-03-09 09:03 PM
Tom wrote:The only way is to make the column into a library object (file/gdl objects/create object from 3D window) You will not get the fills though without editing the library part & adding the fills/lines in the 2D window.
Any way to get a column to show up on more than one level. I have a column that goes up continuously four floors. I thought it would be a construction element that would show up dashed on the floor above. Or at least have a setting that would allow to show up on the floor above or below like some of the other elements have.
