Multiple display
I'm new to Archicad, and still trying to adjust from Autocad 2000....
is it possible to have two separate views up on the screen at one time? In Autocad, I could have two separate areas of a floor plan, with a split screen set-up, to match/copy/etc from one area of a plan to another.
Also, is there a 'measure' tool as in Autocad, (but not the coordinate boxes or technique) to measure distance from items? Without dimensioning the objects? Example...I want to measure location of a window frame from edge of wall?
Thanks-
13 Replies 13
No help with the multiple views... still a wish. To measure either draw a line and esc before finishing reading the distance in the coordinate box or better use the option & shift keys to place a temporary origin and mouse over the point you need to measure and again read the distance in the coordinate box.
Link
Hi Katherine!
You can have multiple windows open in ArchiCAD, just not multiple floor plan windows! Well actually, you can't have multiple 3D windows open either, but you can have as many sections, elevations & details open as you like! Although be careful, because each window will at take extra RAM.
The easiest way to measure in ArchiCAD is to relocate your user origin and then move your cursor and read the coordinates. Do this by clicking on the User Origin button in your coordinate box, then clicking where you want to measure from. Then simply hover your cursor on the node where you want to measure to, and read the values in the coordinate box. You can also copy and paste these values by hitting the X, Y, R, and A keys. To return the origin back to the project origin, simply double click the same User Origin button. Feel free to download the attached file and watch the Flash demonstration on how this is done.
Alternatively, you can hold down the shift and alt keys and hover your mouse over the node you want to measure from. This will position the user origin, then you release all keys and place your cursor over the node you want to measure to. This can sometimes be confusing to new users, as the cursor can tend to 'turn white', so try holding down the alt key, then hitting the ctrl key.
Hope that helps!
Link.
What I do is install 2 copies of Archicad. Then have each floor plan at whatever scale open in each monitor. Then do the copy and paste from one to the other.
Djordje
Exactly for the reason of no confusion, I always preferred starting a line adn hovering its end over the other distance point to moving the origin. The one of the useful applications of ESC now is cancelling that line.
How was that one about old dogs ... ?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Link
Can I presume that dog learnt this trick in AutoCAD, mate?
Good to hear from you.
Link.
Actually, I use a circle, and not a line.
This way you get the rad of the circle, which is the distance you want to find about, and you get a visual output: the size of the circle helps you to understand the dimension (after all, we are visual artists).
And no, I didn't learn it on the AutoCAD, it just seemed to me to make sense
Link
Well you can read the radius of a line too, and read the same R value using the method I suggest, but if you find a circle works best for you, then that's what's important.
Link.
Link.
You are missing my point, Link. Unlike working with the origin and reading the data, and more than looking at a line and reading the data, the circle gives you a visual dimension. As I draw it, I can SEE the dimension, and not just read it in the bottom line.
Have fun
Krippahl wrote:
.........the circle gives you a visual dimension. As I draw it, I can SEE the dimension, and not just read it in the bottom line.
Have fun
Where is this "visual dimension" I do not see a text, changing next to the radius inside the window. Maybe you could give a screen shot?
Thanks,
Joseph
