‎2004-11-19
10:42 PM
- last edited on
‎2023-05-26
03:19 PM
by
Rubia Torres
‎2004-11-20 02:16 AM
‎2004-11-20 03:17 AM
‎2004-11-20 07:51 AM
‎2004-11-22 07:24 PM
Link wrote:Exactly for the reason of no confusion, I always preferred starting a line adn hovering its end over the other distance point to moving the origin. The one of the useful applications of ESC now is cancelling that line.
The easiest way to measure in ArchiCAD is to relocate your user origin and then move your cursor and read the coordinates.
‎2004-11-22 07:35 PM
How was that one about old dogs ... ?Can I presume that dog learnt this trick in AutoCAD, mate?
‎2004-11-24 03:05 PM
‎2004-11-24 04:08 PM
‎2004-11-24 04:48 PM
Link wrote:You are missing my point, Link. Unlike working with the origin and reading the data, and more than looking at a line and reading the data, the circle gives you a visual dimension. As I draw it, I can SEE the dimension, and not just read it in the bottom line.
Well you can read the radius of a line too, and read the same R value using the method I suggest, but if you find a circle works best for you, then that's what's important.
Link.
‎2004-11-24 06:58 PM
Krippahl wrote:Where is this "visual dimension" I do not see a text, changing next to the radius inside the window. Maybe you could give a screen shot?
.........the circle gives you a visual dimension. As I draw it, I can SEE the dimension, and not just read it in the bottom line.
Have fun
