2004-11-11 03:18 PM - last edited on 2023-05-26 03:19 PM by Rubia Torres
2004-11-11 04:21 PM
2004-11-11 04:59 PM
2004-11-11 07:21 PM
Thompson, wrote:
I'm not sure if this is true in 9 but in 8 if one of the parts in the selection set had the values you were changing to (you already changed one windows trim color), the changes would have no effect. It only seems to work when the new value isn't used by any of the selected parts.
2004-11-12 09:43 AM
I'm not sure what the AC protocol is. Does it make any difference if I select windows through the marquee or the arrow tool. It seems AC changes the last one selected, or something.
I can't seem to get them all to change at once.
2004-11-12 10:16 PM
Susanne wrote:This makes a good case for eliminating the use of separate objects for each door and window type. There should be one window (or door) object with all the types handled as parameters (a la Theometric, or whatever it's called now.) It's very frustrating to have to set up (or change) multiple window types to all have similar sills, line weights, trim, etc.
Unfortunately, if the different types of windows used in project does not have the exact same parameter name (for your material f ex) and value string in the 3D script, AC only changes the parameter for all the latest drawn types of windows as you mentioned (the ones that has the same name ...)
2004-11-12 10:43 PM
2004-11-12 11:31 PM
2004-11-14 03:15 AM
woodster wrote:This is true, of course. But it is only a weak, partial fix for the situations I was referring to. In your example, where you want to change only a few parameters of previously placed windows, the current programming works well. However, when building a model that contains several different window types that will share many parameters (interior colors/materials, exterior colors/materials, interior & exterior trim, sill configuration, line weights/colors, etc.) but not type-specific ones (obviously), the current situation of separate window objects does not allow one to quickly (such as with the eyedropper) transfer those parameters.Dave wrote:Susanne wrote:
In ArchiCAD 9, with the use of "Subtypes" in library parts, many components of different objects of the same subtype can be changed without affecting all parameters of the objects.
2004-11-15 06:57 AM
Dave wrote:No Dave, you are right. The current situation kind of s__ks. Though it is beginning to improve with the subtypes, there is still a ways to go. In fairness, it is an understandable problem in a program which has had parametric objects evolving for so long and with so many different versions and sources of library parts over the years.
The quickest work-around I've found is to ignore the shared parameters at creation and then FIND & SELECT them all afterwards to change them. But to be sure all windows change to the correct settings, I have to change them twice--first to wrong settings and then the correct ones.
I don't see any advantage to the current situation of separate objects. I'm not a "power user", so if I'm missing something here, please let me know.
