ā2004-11-11
03:18 PM
ā2023-05-26
03:19 PM
Rubia Torres
ā2004-11-15 08:02 PM
Dave wrote:If I understand what you're asking for Dave, you kind of have this capability now with 9.0, but only as you choose to place NEW windows (or doors) ... not to modify existing, placed ones.
[However, when building a model that contains several different window types that will share many parameters (interior colors/materials, exterior colors/materials, interior & exterior trim, sill configuration, line weights/colors, etc.) but not type-specific ones (obviously), the current situation of separate window objects does not allow one to quickly (such as with the eyedropper) transfer those parameters.
ā2005-02-15 12:28 AM
9.0 has a new parameter transfer mechanism in the Object Settings dialog.In no way is this working for me. After ctrl-alt-click (syringe) onto the THUMBNAIL and placing the window All matching parameters have NOT been transferred (materials, etc.).
For example, suppose you have a wood casement window that you have set up with all of the materials, frame/trim sizes, etc that you want, and you now need to place a double casement, double hung, whatever.
ā2005-02-15 01:24 AM
Jay wrote:Are you sure you are clicking the Thumbnail and not the Preview? Clicking the Thumbnail works every time.
ā2005-02-15 02:48 AM
woodster wrote:Yes
Woody
ā2005-02-15 03:47 AM
Dave wrote:Amen to that dave!
...This makes a good case for eliminating the use of separate objects for each door and window type. There should be one window (or door) object with all the types handled as parameters (a la Theometric, or whatever it's called now.) It's very frustrating to have to set up (or change) multiple window types to all have similar sills, line weights, trim, etc.
ā2005-02-15 07:22 AM
Jay wrote:Hmmm. There are a number of possibilities, Jay. One is that the windows you are using have the same English text prompts for the parameters, but the internal GDL parameter names differ. This could happen if you are using old windows, or transferring parameters of windows from a 3rd party library and AC 9 or 8.1 windows.
Now that I am finally using AC9, I have tried this9.0 has a new parameter transfer mechanism in the Object Settings dialog.In no way is this working for me. After ctrl-alt-click (syringe) onto the THUMBNAIL and placing the window All matching parameters have NOT been transferred (materials, etc.).
ā2005-02-15 05:32 PM
ā2005-02-15 05:58 PM
It does not work if you have selected an object BEFORE ctrl-alt-click (syringe) onto the THUMBNAIL.Nope - that's by design mate, so the method you are now using is the correct one.
Does anyone know if Graphisoft is currently addressing these or similar issues???...Yes they are - ganging windows should be much easier in upcoming libraries.
